I've been pondering my build. Here is my question. Would you choose to be locked front and back or have tons of flex. You can only choose one, tell me why.
Locked front and rear most def. The capabilities with all four tires turning are 10 fold over open diffs. Even with tons of flex your still not getting power to all 4 tires. Granted your tires may be on the ground due to insane flex but only 2 of them will be spinning when under load. You really aren't gonna get anywhere in this situation. Lockers will propel you forward even if you lifting a tire. Power is sent to all 4 regardless of the load or position they are in.
I'm 50/50 on this one Having traction is nice but I've been in alot of situations where as long as you can keep your tires on the ground or as close to it as possible you can go just as many if not more places that a rig with stock to no flex suspension and lockers can. Doesn't matter how flexy or traction available you are as the driver style will always be a factor.
I've watched my rig fail miserably on RTI ramps...somewhere between 500-600 (best I recall) on the last one...it's a whole different story on the trial, with a low COG, fairly flat underbelly, ARB's front and rear...
anybody that's seen mine on the trail will agree...I may lift a tire, but it's not gonna be stopped due to lack of flex...
Nick, I assume you're keeping the 44/9" combo? I'd just get some lockers off someone on FSB who's going to 1-ton gear and call it a day. Since you're solid up front, you'll have an easier time tuning the suspension than us TTB'ers. But that can wait. I'd get traction first.
