uncc civilengineer
- Jun 28, 2006
- Pfafftown, NC
Ok, I picked up a rig this past week and i'm in the process of going through it before I take it out... I have some issues to address and one being the rear end.
It's a 9" w/ 5.14's, Detroit, chromos, discs... The issue is I have a wierd noise when coasting (not under load)? kind of a whine but it doesnt sound like locker noise. I also have gear oil coming out both ends of the tubes and coating the rotors, calipers, pads, etc...
Anyone have some advice to offer to steer me where to start? I've never messed w/ a 9" before.
Thanks,
EDIT: I wanted to revisit this now that I've put everything back together...
I replaced both bearings w/ Timken Set20's (found them for $25 each on Rock Auto)... no leaks, spins freely, etc. New Driveshaft u-joints, etc...
When driving around 55+ I'm getting a loud whine... sometimes i get the same noise when coasting/slowing down. Seems to go away under load... but when cruising it comes back.. Is this gear whine? When i took everything apart, there were are no metal shavings, etc. in the gear oil. If it's gear whine I'm fine w/ it as long as it's not going to hurt anything if I drive it on the road some. I'm also assuming the only way to remedy the problem would be to setup new gears?
Any way to easily tell if something's wrong w/ the Detroit causing the problem?
Thanks,
