ford 9inch or dana 60
cheapcherokee89
oxford
looking into going fullwidths, gonna run hp44 up front but not decided on a 60 or 9inch rear. only gonna stay around 36 inch tires with a stock 4.0. Whats some oppinions here? if i go with the 60 it will keep the stock shafts, not going to upgrade to 35 splines. would the 9inch hold up fine against 36s or would the 60 be a better plan? thanks
9" and 60 are about the same strength. The more important part is lug nuts. I would reccomend to go 8 lug so later when you want to upgrade the front to a dana 60 then you won't have to buy new wheels.
