I use to drive and wheel an 85 full size Ford Bronco. First, I would recommend making sure all your ball joints and tie rod ends are tight. Second, make sure the TTB arm bushings are not sloppy. Third, check the radius arm bushings and make sure they are not worn out. If there is any play or wear in anything, then replace. Fourth, if your front shocks are old as dirt, replace with some new ones. Lastly, take it to a competent alignment shop that can correctly adjust the Ford TTB. There are replaceable numbered steel alignment bushings that slip around the upper ball joints to set the caster and camber for each wheel.
Im trying to sell it
Thanks guys. I kinda knew what to expect, but not really. It was taken to an alignment shop after it destroyed a almost new set of 37" SSRs. But they werent able to find anything loose or wore out :/
Any clue on the cost of repairing?
And thanks again
Too $ for poor ol country boy like me. lol
