NCJeeplover
- Jul 25, 2009
- Claremont, NC
I am having trouble with a truck I recently purchased. Its a 2000 F450 V10 5 speed truck. It's throwing 3 codes currently;
PO135 - Bank 1 Sensor 1 heater malfunction.
PO155 - Bank 2 Sensor 1 heater malfunction.
Both oxygen sensors appear to be new, they ohm out good also. There is no voltage at the oxygen sensor heater pins.
PO443 - Purge Control Valve Circuit Malfunction
I have ohmed the purge solenoid and it is in speck. There is no voltage at the plug for the selenoid either.
I've checked all the fuses and they are all good. I'm leaning to the ecu being bad and not sending voltage to these things.
I would love to put a meter to the power wires at the ecu just to double check and see if there is no voltage coming from there before I drop 300 bucks on a new ecm. Does anyone know what pins supply voltage for the solenoid and o2 sensor heaters?
