i have a 78 k10 chevy and the frame is starting gto crack around the steering box i was told these trucks were bad about this is there any solution to the problem or should i just weld the cracks up and see if it holds
if you can locate the end of the crack,be sure to drill a hole threw the frame before welding the crack,this will stop the crack from going any further.
