Front Anti-Wrap Bar??? Is it possible?
gogogadgetbiker
Greenville NC
OK so this Saturday was the first run for my 2002 GMC Sonoma ZR2 with a D60/14Bolt. I run 1410 joints at the bottom of both D-shafts and saturday I snapped a pinion when the 1410 joint up front bottomed out due to axle -wrap. I have already convinced myself to take the plunge and cut&turn the D60, but to eliminate this problem for good I was thinking an anti-wrap bar up front. I can't think of any reason why I couldn't make it work but I can't find anyone else who has tried it, only people who want to try it. So my question is simply will an anti-wrap bar work up front with a reverse shackle setup "shackle to the rear?"
yes
also helped build a truck with d60 front and a track bar to the front tied into spring mount on frame
had 39 TSL's, 4.56's, detroits...worked awesome!!
good luck :beer:
