Front left wheels moves back and forth
cr817
ROCK HILL
I was putting brakes on yesterday and I can rock the front left wheel around. I can only assume it's the wheel bearing. Since I have to change it should I be looking for anything else while I'm in there? Any ideas?
what axle??
I would rock it back and forth, you should be able to see where the movement is coming from. I did this last night, and as a result, I am replacing ball joints tonight.
My bad 94 wrangler 6"lift 35 12.50.
I can move everything as one unit. With the wheel off I can grab the whole thing and move it around. It accually looks like everything is tight untill the axle.
Wheel bearings will move in out if they are dead.
