Jeff B Thanos was right Joined Dec 23, 2006 Location Lincolnton N.C. Sep 21, 2008 #1 Drained a little fuel out today & this damn think won't stop leaking. Can I just plug the damn thing off?
Jeff B Thanos was right Joined Dec 23, 2006 Location Lincolnton N.C. Sep 22, 2008 #2 I capped the line & put a couple of clamps at the valve. Still leaking a little. ordered a viton o-ring kit to rebuild the valve. Has nobody had this problem?
1983Bronco Well-Known Member Joined Apr 10, 2005 Location On your mom in Winston Salem NC Sep 23, 2008 #3 Just bypass it, I did it on an older 7.3, mine was letting air in causing all kinds of trouble.
Jeff B Thanos was right Joined Dec 23, 2006 Location Lincolnton N.C. Sep 23, 2008 #4 How did you bypass it??
greg slade The Moderated Joined Mar 21, 2005 Location timberlake Sep 24, 2008 #5 i had to rebuild mine after the switch to ULSD fuel. Its no big deal and a fairly common problem. Just rebuild it and you will be fine. it takes maybe 5 minutes.
