Fuel Tank Venting Ques.
Devo
Raleigh,NC
Here is what I have:
'95 YJ 2.5
AX-5 (5th is gone, surprise, surprise)
Here is the problem:
The tank venting system seems to be allowing fuel to slosh out. I cant fill up more than half a tank. If I do any time I make a right hand turn, gas sloshes out of filler neck at the cap. Gas also escapes through the actual vent lines up where they mount inside the driver side fenderwell. I need to replace the fill neck because the filler neck flipper broke off and is the tank somewhere. That wouldn't explain the fuel sloshing through the vent lines though. Anyone have any ideas?
probably need new filler hose and or the filler/vent. also on my yj tank, the top vent/roll over valves the gromets seem dry/brittle so its possibe on your it could be leaking there also...
