full-hydro, which orbital?
Tacoma747
Winston-Salem
I have two orbital's, which should I used for my buggy?
One has 4 fittings on it, one has 5, other than that they look about the same.
From what I've found, the 5th can be used for "optional" hydraulic functions, such as rear steering.
I don't plan on having rear steer, so is there anything that that extra fitting could be effictively used for?
Thanks
Really it's a shot in the dark with either of them, unless you can get somebody to look up the numbers (if they have a tag)
They may or may not work, could be 1 turn lock-lock or 10, might overheat your pump (I can't remember what it's called, but not all of them will work with an automotive PS pump). I've tried some, and the wheels turn when the steering wheel is not turning.
You may be able to just block off the 5th port, I've read that works sometimes. I tired it on one, it didn't.
There are hundreds of different speced valves, only real way to find out is to hook it up and try it. Good thing is, *most* of them mount the same.
