full traction t case drop?
Tim
sanford
3" full traction lift
since I purchased the rear upper arms will I need to do the t-case drop when I get the rubicon lifted?
If I dont need the drop then Im definitely gonna be happy about all the extra clearence
I thought that the Rubi's had SYE from the factory. If so then I wouldn't see why you would need it. Have you checked one of the rubi forums to see what those guys are doing?
I would say put the lift on...drive it and see if there are any vibs. If there arent any vibs it should be fine...if there are put the drop in, I dont think they are that hard and don't take very much time.
well from what I understand I needed the rear upper arms to correct the pinon angle...so if that does the trick I shouldnt need the t case drop..Ill tell them to leave it off first
No transfer case drop needed. on the 97-03s you would drop the t-case but on the 04-06s you utilize adjustable cams on the rear upper or new adj. uppers like the ones you purchased. IIRC
You should be in great shape.
My friend's rub unlimited has more lift, but he put t-case lowering kit and 1" motor lift. I don't personally know, but that's what kept his drive line in correct angles.
