RatLabGuy
- May 18, 2005
- Churchville, MD
Short version: on a modern car with ECU control over efficiency etc - when you're rolling along at high RPM in a manual trans car, and off the throttle - is any gas being put out while you're coasting?
Long version: There's a long slow downhill near here thats like 2 miles long, I find it fun to push in the clutch and just coast and watch the car's MPG's hit 99.9 and think to myself, "I'm using no gas." Which isn't really true bc it idles down to 500 rpm while the clutch is in, and that idle still takes a small flow of juice. I was talking to a coworker and he said, you're better off leaving it in gear and backdrive the motor bc as long as its higher than the idle RPM the ECU will know it doesn't need to apply any gas. Or at least, it will not be told it needs to.
Is that right? I'm not into hypermiling or anything, just idle curiosity (see what I did there) and found it a fun thought experiment.
