OK, now we'll tell you the right way to do it..
take the knuckle apart, and pack the grease into the birf like you would a wheel bearing. put a little on the new axle seal's rubber (if you're in there, replace it), put the axle shaft & birf into the housing and liberally grease around the inside, but you don't have to pack it full.
the way you did it doesn't get any grease into the birf, which is what needs the grease most. it's also gonna make one fawking HELL of a mess when you break the birf!
