Gear pattern Advice
thecj3man
Fall Branch, TN
Setting up a new 9” third member to put in my old car. Everything is new except the locker. I was pretty happy with the pattern, but also undecided if I should move the pinion depth a little to try and center the contact. Thanks for any advice.
The backlash is 0.011. The US Gear instructions say 0.008-0.012. I tried to go a little tighter, but if I go tight enough to get to the next set of adjusted holes the backlash is about 0.006.
I always set my yota 3rds up a little tighter than normal just so there is that much less deflection. The was a 98% trail rig with "rubber" gears tho so, plan accordingly.
Street car. I like the backlash not plum loose but middle ground. Higher rpm better oil distribution, less gear face heat, and maybe a little less rolling resistance.
Due to gear design of a 9" they like wider backlash .011 is good and that pattern is good.
Good decision on using a US gear - that is all we are using for 9" with excellent results
The US Gear was reccomended by Strange. The US Gear wasn’t that much more than the eBay special gears. I used their third member and pinion support so I figured I would use their preferred gear set. I am very happy with everything I got from Strange.
I used to enjoy getting some Strange too years ago. But after a while, when you almost call her by the wrong name the next mor-...wait, what were we talking about? :lol:
Damn nice pattern though. I'd run that all day!
