Deep. You see the distinct flat line at the base of the contact patch?
Remove 0.005" from the pinion shim stack and re-run the pattern. Apply pressure to the ring with a prybar while turning the pinion. It'll yield an easier to read pattern
This is the best I can get it to do. Took a couple more thou out pinion depth. Keeping pressure on ring gear while rotating pinion. This was a used gear set from @jeepinmatt .Can't remember if they were ever actually ran or just installed. Pinion preload 15. 8 backlash. This is not my first set of gears but the pattern looks odd.
