Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
Just wanted to hear some thoughts and opinions on my next move.
I finally bit the bullet and bought some 37x12.50-17 Cooper STTs and they're simply awesome so far. I love them! They're quiet (for now), balanced out GREAT for a 37" tire, they look great, and they run surprisingly true. The most weight in one spot was 5 oz and I think that's great for a tire that's about 85 lbs. Anyway, I can definitely feel a tire under the truck now compared to the slick 315/70-17 BFG ATs I was running since I did the SAS on this truck.
Currently, the truck has 4.10s. It does alright, but I can tell it takes longer to get up to speed and I certainly have to drop back to 4th gear more than I used to. I'm thinking 4.56s will get me right where I want to be, plus I already bought a used set from @Jody Treadway a while ago for the front and got a killer deal on them.
The front is a 79 Ford hi pinion 60, the rear is an AAM 11.5. I'll probably do the front myself, I've already done it once when I went from 3.55 to 4.10, the same shims got me right where I needed to be, maybe I can get lucky again.
Anyway, here's some math and hard numbers. I usually base my gearing needs on 65mph in 5th gear as that is my most common speed when I'm running up and down the highways. Also, my cam starts to make torque right at 2000 rpm and that's its' happy spot.
The Coopers measure about 36.25 when mounted and with weight on them. The old BFGs measured 33.125. The 336 is a constant, the next number is gear ratio, 65 is the speed, and the .73 is my 5th gear ratio.
Old tires: 336 x 4.10 x 65 = 89,544 /33.125 = 2703 x .73 = 1973 rpm @ 65mph
New tires: 336 x 4.10 x 65 = 89,544 /36.25 = 2470 x .73 = 1803 rpm @ 65 mph
New tires and new gears: 336 x 4.56 x 65 = 99,590 /36.25 = 2747 x .73 = 2005 rpm @ 65 mph
85 mph would put me at 2622 rpm.
Now then, I know re-gearing to 4.56 to gain right at 200 rpm might not seem worth it...which is what makes me think maybe I should try 4.88s. A few companies make a 4.63 for the AAM rear, but I haven't found any for the Dana 60. At least, if I did, I can't remember.
Here's 4.88s:
336 x 4.88 x 65 = 106,579 /36.26 = 2940 x .73 = 2146 rpm @ 65 mph
85 mph would put me at 2806 rpm.
With all that laid out, I never plan to go larger than 37s....ever. Not with this truck and not with the price of tires! I think the 4.56s would suffice and since I already have a set for the front, that's why I'm leaning towards them. Also, if I ever make a long trip, this would be the vehicle I use and interstate speeds are higher which would lead to higher RPMs. I added those in for consideration. Wheeling isn't as big of a concern since first gear is 4.02 and low range is 2.72 and that crawls fairly decent with such a torquey cam. This is also my "nice" truck, so I try not to beat it up too bad.
Sorry for the long post, but let me hear what yall think! Also, since Jody is booked solid for a while...who else does gears? I'm thinking of just rolling up to the guys at ECGS and letting them do it since I need the inner Cs cut off my front axle to get the camber straightened out anyway.
Here's 4.88s:
