Getting out of the hobby vanquish ax10 gatekeeper lipo and lots more
SPERD
Staley nc,27355
Lipo GLACIER batteries 1300 mah x5 they were charged and balanced 3x AND
onyx 245 Lipo dual charger used 3x has paper work and original box and ends charges and balances life lipo nicad NiMH batteries 100.00
losi crawler shocks with 4 gold and 4 white and 2 silver springs and adjustable pistons and 2 tubes of shock oil 40.00
Link Drill Guide Set by JeepinDoug 10.00
Built Ax10 front and rear axles 140.00
I would part the axles out if anyone is interested
The front axle has overdrive gears bta steering axial aluminum knuckles axial hd locker and hubs vanquish battery plate aluminum servo mounts and 13mm jufac wheel wideners and some kind of aftermarket axles they were installed when I bought the rig.
Rear axle has Vanquish Products Incision Shock Mount Razors under drive gears 13mm junfac hubs some kind of after market axles axial HD locker
Novak 55t brushed motor with 3 sets of pinion gears 32 pitch 20.00
Novak goat esc good up to 2 cell lipo built in cut off 40.00
Soft sipped rovers with double duece foams and all adjuster rings included mounted on axial 8 shooter wheels 60.00
Gatekeeper ax10 chassis with links and plates and instructions powder coated yellow 65.00
Call or text me 336 380 7609
i might be interested. i have a wraith thats being upgraded, so id like to add some random parts for a truly custom rig. how much are you asking for it all?
pm me a package price picked up on the goat esc and 55t motor
