- Mar 17, 2005
- N. N. Raleigh, NC
ok, Im trying to fix the A/C on my truck and I have a few questions.
If i jumper the low pressure switch the pump turns on and works. And it does make cold air. (I didnt leave it on long, im assuming its not working for a reason). So I replaced that (low pressure) switch with a new one.
I've tried charging it with the DIY kit. (Note this is a factory R134 setup) says i got the correct amount of pressure 15-18 psi and it seems to hold the pressure fine.
What should i do next?
Was reading its possible its been charged with too much oil ?
(I know previous owner tried charging it also) If so how do i get that out ?
Anyone got a vacume pump thing to 'evacuate' the system? Should i replace anythign else? Id like to keep it <$100 is possible.
HELP !!
-mike
HELP !!
-mike
