Good Repair Shop for Suspension Damage
Cherokeekid88
High Point, NC
Well my Cherokee was hit Sunday night. basically, no body damage. They hit my rear right tire which bent my main leaf spring up about an inch at the frame mount end. pushed my jeep up onto the curb which knocked something out of wack as my steering wheel is turned 90 degrees to the right while driving straight and my axle is not centered under the body. Allstate said estimated about $800 worth of damage and I have a $500 deductible. But the claims adjuster said that more than likely there is more "hidden" damage that I can't see, so he told me to take it to a place of my choice and get them to figure up what needs to be done and they will cut me a check for whatever else needs to be fixed.
My question is..What is a good shop to take it to that is around the triad area?
I have dealt with D&M Motorsports before and they are great but just wanted to see if you guys knew of some other good shops.
EDIT: Sorry I think I posted this in the wrong section.
take it to a body shop with a frame rack, and let them write-up the estimate... then, you can fix the parts yourself..
