I need to know what the specs are for a 1998 grand cherokee is. We just got the 4" lift put on this weekend and we need to get the alignment done on it. Any suggestions would be great.
Which specs? There are a bunch of specs on jeepforum.com. Heres the link to the ZJ specs http://www.jeepforum.com/forum/showthread.php?t=150055 . Just look through that and maybe you will find what you are looking for. For the alignment you could just do it yourself. Just use a tape measure on the front of the front wheels...then measure on the back of the front wheels and make sure they are the same distance (if not adjuste the tie rod). You might want to point the front wheels in towards each other about a 1/16 of an inch that way it will help you drive straight when you let go of the wheel. Sorry if thats confusing..you can use a serach and it will probably come up with a way that explains the alignment alot better,
Mike, just go to a Goodyear or Discount tire, don't align it yourself unless you want to wear out tires. The Discount Tire right by our shop is where I take my alignments and it's not far from you, they always do a good job for me.
When you can get an alignment done for $65, why do it yourself and risk wearing out expensive tires. I'm sure you can get it close, but not like an alignment machine.
