i dont think so, isnt a ZJ slightly heavier? theres a possibility it'll be LOWER. i dont think the coils are any longer and witht he extra weight itd be a downgrade.
ive heard if you take the rear springs off of an xj it will give a grand cherokee some extra height. i used to have a lifted grand cherokee with a 3inch pro comp lift and the guy that told me this said all he did was swap springs and his was about the same size as mine. not sure if he did anythiong else though.
an xj has leafs in the rear... zjs are heavier then TJs so as said, itd prob give you less lift... if you have a 4.0L, you can get V8 upcountry front springs for the front and put stock fronts in the rear, for a small budget boost.... also I have heard of TJ guys doing the same thing with ZJ coils and stock coils in the rear...
but to use a TJ coil on your ZJ, youd probly haveta get one that is alot bigger then the lift your looking for, to get the effect on the grand...
