- Mar 10, 2005
- Hooterville (24171)
Since my CTD came with an 80gal AL bed mounted tank & electric switching valve (operated via dash mounted switch, which supposedly switches the fuel gauge also [aux. tank has sender/float])...
Can I get away with simply using a HotFox type coolant heated pickup?
Or if needed, since I de-plumbed the OEM tranny "heat exchanger" (guaranteed to make anything flowing thru it 180*+ ) guessing it could be used for supplemental heating prior to hitting the valve?
Also, what's the best bang (micron vs media cost) on a filter to plumb between the tank & valve?
