Greenville, NC metal
iwaxmyjimmy
College Web Wheeler
Greenville NC
Where do y'all get your steel from? Need to pick up some 1/8" sheet, 1/4" sheet, and I need to check and see what tubing I need to redo a friends shock hoops. I known Archie by LQK(Foss) for a long time but just curious who y'all get your stuff from around here.
Dillon supply has decent prices on small qty tubing and can get exactly what you need. Archie's is hit or miss with tubing but has fair prices on standard structural shapes and sheet.
Thanks I probably could have just texted you and asked but I figured why not.
BMG in Wilson has been good with most anything I have purchased. They used to deliver; not sure if they still do or not.
Meh I just need one sheet of 1/8" to finish my corners on the jeep, some 1/4" to do my spring swap on my k5 I doubt they would deliver 2 sheets for a decent price.
As long as they don't mind helping put it in my garage I'm cool with it. But I'm assuming I'd need to have it dropped off at a business address
They won't help put in the garage. You are on your own for that. About as much as they will do is take the straps off of the flat bed. They typically don't care where they drop it off as long as it's a reasonably easy in and out. They will pull in front of your house if need be.
If they put it in the drive way I wouldn't mind that
Gotcha, sounds like I'll have to invite a few friends over for some beers for the delivery. I need to buy a truck so I can just haul this stuff.
Weld a tab to it and use my engine crane lol
That would work too
