RatLabGuy
- May 18, 2005
- Churchville, MD
Ok so I just installed a rear 3rd w/ 5.29s.
Now up front I'll say I don't know the history on the piece or the setup, the guy I bought it from (yes, a member here, and no, no names) said he didn't know and he hadn't run them (project change, yada yada).
Yes, this is a classic case of "don't buy used gears w/o some good info, and esp don't wait a season to install them".
I only did the rear first to check it out.
Anyhow, I just took it out for a short spin (2 miles?) and they are pretty noisy... whine that increases in pitch (and volume) w/ speed - but ONLY when applying gas. popping into neutral or just letting off the gas makes it stop, they sound reasonable.
I did a quick dab of gear marker before putting them in, it seemed reasonably centered, but I'm no expert. unf didn't snap any pics.
I did notice there was very little resistance on the pinion, I could very easily turn it by hand; the old set (4.88s set up at CRS) very much more tight. No obvious wobble/wiggle or anything though.
Any thoughts? i'm wondering (hoping) the pinion nut might just be a little loose?
