paulevans76
- Mar 21, 2005
- York, SC
I've got a y-link radius arm setup on the front of my rig, and the panhard mount and high steer stuff limit my uptravel and keep my ride height higher than ideal. Ideally, I could lower the rig an inch or two and keep or increase uptravel. I was thinking about options and I'd like any feedback y'all might have.
Currently, the panhard mount is on top of the axle, pretty much right under the frame. Almost totally flat and parallel to the drag link.
One option would be to move the axle side panhard mount to a lower spot on the axle, and move the drag link and tie rod down to match - either to underside of the high steer arm, or mount to the original steering arm.
My fear in doing so is that this may negatively affect handling. I like to be able to drive a couple hours to the trail and back, so street manners matter. Currently street manners are marginally acceptable so I don't want to make them worse.
From what I've found, the higher, flatter, and longer you can keep your panhard, as well as parallel to drag link, the better. I don't think I'd be moving my roll center much if I'm just moving the axle side mount lower. The current angle is basically flat, my radius arms a pretty much flat at ride height, but the rig is tall and heavy, so body roll is pretty pronounced.
Other options would be to go to a SUA leaf set up, but that really would be a shame and I'd lose a lot of under axle clearance.
Any opinions?
Any opinions?
