motobilt
- Jul 25, 2013
- Dothan, AL
ADJUSTABLE TRACK BAR AXLE BRACKET
MB1542
$45.99
The Motobilt adjustable track bar bracket is built to take the any abuse you can dish out. This bracket is laser cut from 1/4" thick steel plate and CNC formed. The bracket consists of 3 pieces that will need to be welded for install. The brackets utilize 3 different holes that measure 5/8" in diamter. The bracket is also offset so that it will clear your other suspension components. We offer the track bar bracket in 3 different axle tube diameters. (3"s, 3.25"s, and 3.5"s) Use the drop down menu to choose.
Sold indivdually.
ADJUSTABLE TRACK BAR MOUNT OUTSIDE FRAME
MB1542
$29.99
https://www.motobilt.com/suspension/trackbars-brackets.html
The Motobilt adjustable track bar bracket for outside the frame is made of 1/4" thick steel plate. This mount is laser cut and CNC formed in house at Motobilt HQ. There are 3 mounting holes that are 5/8" in diameter. This bracket was designed to fit on the outisde of the frame but we also offer one for inside the frame too. (pn# MB1541)
The mounting width of the bracket is 1.75"s.
These are sold individually.
ADJUSTABLE TRACKBAR INSIDE FRAME MOUNT
MB1541
$29.99
The Motobilt adjustable trackbar insde the frame mount is made form 1/4" thick steel plate. We laser cut and CNC form these brackets in house and they use a 3 holes with a 5/8" diameter. These mount on the inside of the frame rail. The mounting width is 1.75"s.
Sold individually
MB1542
$45.99
Sold indivdually.
MB1542
$29.99
MB1541
$29.99
Sold individually
