HELP!!!!! ASAP
drock1231
Member
Seven Springs
ive got a chance to get a set of chevy 1tons but there out of a dulley what have i got to do to to get them the width of a regular dana srw 60 and 14bolt! Any help would be aprecaited and asap thanks.
You will need to get hubs from a chevy single wheel D60, which are about $250ish, or get the hubs machined down. The dually rear is about 4" narrower than the SRW (63.5 vs 67.5"), so you could run spacers or just deal with it.
You can cut off the dually part on the front axle. It's basically the same except it has an extra part that spacer the wheel out. The rear is narrower, but you could trade it.
