SHINTON
- Mar 17, 2005
- Triad area of NC
The Excursion is having a few glitches and at the moment will not do anything/respond, HELP!
Ok, will give you more info than you need but maybe you will spot the issue.
First..Clifford alarm system installed by previous owner, includes remote start and basic alarm.
Second..stupid door sensor in drivers door has been out a month or so, has not been a real problem to date other than the dome light and running boards stay on for 10 minutes after leaving. (And I cannot turn on the alarm since the door is open, so the Clifford has not been used for a month or so)
Third...about a week ago, headlights just stopped working, I had running lights, fog lights, etc. Dealer took a look and found "loose wires" and blown fuse and fixed. (They still work at the moment btw)
Ok...so went to work yesterday, shut off as normal, locked doors via the PDL, etc. Did NOT arm Clifford system.
12 hours later ready to go home...noticed alarm LED was flashing rapidly. Pulled out my key fob to "disarm" and nothing, but fob is working (I see an LED that shows it is transmitting)
I figured alarm would go off, but nope, opened door (with key), ok, tried to turn Excursion on and flashers now start flashing (but no siren)....again I attempt to use key fob and the manual control on clifford to 'disarm' but no such luck.
The "normal" dash lights to indicate glow plugs warming and all the others are NOT COMING ON at all. THEFT does flash every 10 secs or so....and naturally you turn to start and no response.
We disconnected batteries for a minute, reconnected, same thing, flasher on, nothing responds. We disconnect them overnight and I snag another ride home.
This morning, reconnect batteries, flashers are NOT on (yeah, maybe something reset), I go inside and turn alarm to valet mode via instructions. Alarm system does NOT seem to respond in any way (supposed to chirp, etc) Alarm LED is NOT, NOT flashing at this point.
Turn key to start position, radio comes on, can turn on headlights, a/c is working, but NO DASH LIGHTS indicating anything else is actually happening and will not start/crank. THEFT continues to flash every 10ish seconds or so.
So...that is where I am now. Left batteries connected, locked doors (via PDL in door, not using alarm fob)....system does not respond at all to alarm keypad or my fob.
I tried flipping the key several times to see if that made a difference and nothing....
At times, I truly hate all the electronic crap on this truck, door sensors, etc etc, more stuff to just go wrong.
So..please HELP, is there any place to "reset" anything I havent done already by unhooking power overnight?
I figure the issue is with the alarm system (Clifford) but really hard to tell at this point?
Sam Hinton
Sam Hinton
