ShimShim
- Apr 21, 2005
- Charlotte, NC
I have a 2007 JKU with 179xxx miles on it. Bought it in January and have been slowly doing maintenance items (oil/filter, diff fluids, coolant flush, valve cover gaskets, etc.).
I had the cooling system flushed about a month ago when I noticed that the coolant bottle was low. I've driven several hundred miles since and I've noticed just a random drop of coolant on the ground under the jeep occasionally. Never more than a drop.
Today, I came out and found this...
That's not a huge amount of coolant (I promise it's coolant, the camera just isn't picking up the green from this angle and with the lighting), but it's enough to be concerning. The curious thing is that the jeep has been sitting for the past five days without moving. I know the coolant wasn't there two days ago. So it sat at least three days before it decided to pee on my floor.
I poked around and looked to see if I could find the source. No evidence of obvious leaking from hoses. The thermostat appears to have no leaks. What I think is the water pump looks dry.
I did find this...
Another angle....
There's just a small puddle there between the valve cover and the throttle body (ignore my ignorance if that's not the throttle body, I know just enough to be dangerous). I can't see a source for where that coolant came from. I replaced the valve cover gaskets a few weeks ago so I pulled that valve cover to make sure it's not coming from there since I'm pretty sure that would be a VERY bad thing. Luckily, no coolant under the valve cover.
Under the hood, there is minor evidence of coolant below that area but nothing concrete pointing me to the source.
A look under the jeep and I found this...
I'm not even sure what that part is that's got the coolant staining on it. And sorry for the crappy pics under the jeep. Had to juggle the phone and the light and try to get the best pics.
I could not find an obvious source from under the jeep either.
So who here is an expert and can either see something I'm missing, or knows the common coolant leak sources on the early JKU?
I did find this...
Another angle....
