ktw0520
- Jan 23, 2009
- greenville
I cureently have a 99 cherokee xj with a 3" suspension lift new springs in the front and leafs in the back. I am running 31x10.50x15 BFG All Terrains. Typical beginner lift for the xj I know. I am looking to go bigger as most would assume. I am looking at adding 2" spacers in the front and 2" shackles in the rear. I already have new shocks to go with current lift so they will hold fine with the extra 2". I have heard different stories from different threads about what else needs to change with the extra lift. So far I understand that the control arms need to be dropped so I am looking at the relocate brackets rough country makes. Also I hear that I need longer brake lines which is an easy $50 swap for steel braided lines. Last thing I see is that I will need new pitman arm. From the experts does this sound about right? From your experience with this is there anything else that needs to be done? Also 33"s ??? Will they fit and not be stuffed in? I don't want to hit a curb and lose my fender!!! I am going to uwharrie and still want to do a little crawling!!!
