hey, lift for CJ7
adam greene
morganton
hey i have a 1978 cj7 pretty much stock just shackels and 2 inch body lift with 35 boggers on it. im wanting to lift it more witch is better doin a spring over or a 4 inch lift springs
shackle lift AND 2 inch body
Are you wanting to ditch the body of 4" springs shackles and 2" body?
If o you would be taller than long.
engrish much either one?
either option of 4" springs or spring over has its pros-and cons, the 4" lift springs would be easier but may be stiffer and limit flex, but may be good if the stock springs are worn out, the spring over would take more work, but may be flexier than lift springs,
personally i would ditch the body lift, do a spring over, and maybe 2" lift springs if you needed a little additional height
