greg slade
The Moderated
- Mar 21, 2005
- timberlake
man this litlle four popper has pushed me to my limits today. i recently picked up a 95 yj with a 4 cyl 2.5l. 165k on the clock. it had recently got a new motor, trans, t-case, all from the dealer all "expertly" put in by the previous owner. after re-installing everything properly and rebuilding BOTH diffs the dang thing wont idle below 1150. its got a aftermarket header and a tb spacer and cold air intake too.
i replaced the iac motor and tried three different tps sensors also i resealed the intake manifold and the tb with new gaskets. still no luck!!
one of my colleagues at my shop recalled that the only GOOD tps for those jeeps came from the dealer. anyway i have verified that there are no vaccum leaks and replaced all vac hoses.
ignition timing and tps range are both non adjustable on this vehicle, sooo????
usually i wouldnt bother with the 4 cyl and go ahead and drop in a LT1 but im trying to build a featherweight this time and besides the motor has 250 miles on it. not rebuilt or remaned but new new new.
i was hoping that some of you who currently run this setup have already came across a problem similar with the aftermarket parts.
my next only choice is to replace the intake manifold, maybe its warped and leaking a little????
TIA, GREG
TIA, GREG
