Ok. so i'm building a 75 high pinion reverse cut dana 44 from an f-150 with a 5 on 5.5 bolt pattern to install in my 95 YJ.
I have the axle (listed above) and I got the 76-92 ford hub, rotor and inner wheel bearing needed for the 5 on 5.5 bolt pattern.
I will need chevy high steer knuckles with spindles and chevy calipers and caliper brackets.
I will also use warn premo hubs.
My question is - will I use the small bearing chevy spindle or the large bearing chevy spindle? I think I will need the small bearing spindle but I am not 100% sure.
Any other input would be great.
Thanks,
Chad
Thanks,
Chad
