Hobart's New Battery-Powered MIG
NC4x4
Moderator
Hobart has introduced a self-contained MIG capable of welding in the field without an additional power source. The 52 pound Trek 180 has two thin plate pure lead (TPPL) batteries inside mated to an inverter-based welder. Together, the system is capable of up to 100 inches of weld with .030 flux core wire on 1/8" base metal. On battery power alone, the welder has a rated output of 120 amps at 17 volts DC with a 20 percent duty cycle. When plugged into a 115V receptacle the rated output jumps to 180 amps. This high output is possible thanks to a more efficient inverter-based power regulator. If that's not enough to fix your busted rig, the machine can be recharged from an automotive inverter (400 watt minimum). Hobart's Autopower system monitors the incoming power and adjusts its draw to avoid overloading small inverters. The Trek will reach an 80% capacity quick charge in 20 minutes. Full charges take about 90 minutes. The Trek 180 will have an MSRP of $1400. Look for it at farm stores and hardware dealers soon. Or check out www.hobartwelders.com for more information. Via UTV Weekly
