smith92rc Well-Known Member Joined Oct 6, 2008 Location concord Dec 7, 2013 #1 anyone in concord/harrisburg work on these atvs. if you have ever had a bad ujoint in a truck and you get on and off gas, it makes a clunking noise, this is the sound my atv is making. would like for someone yall recommend to look at it.. thanks..
95ford150 Active Member Joined Feb 16, 2009 Location Rowan Dec 7, 2013 #2 Drive lines are relatively simple on them. Not saying that is your problem.. But could be. You may can remove the rubber boot far enough to check the U-joint. Been a while since Ive messed with one. http://www.motosport.com/utility/oem-parts/HONDA/1996/TRX300-FOURTRAX-2X4/SWINGARM
