99ncxj Well-Known Member Joined Sep 23, 2006 Location Aliso Viejo, CA Feb 26, 2008 #1 just wondering if there is a measurement guide to determine u joint sizes. Mostly interested in 260's vs. 297's.
willness33 Here for the memes Joined May 3, 2005 Location Alexis,NC Feb 26, 2008 #2 The 260 cap is less than 1" in diameter, the 297 is greater than 1" in diameter. Can't give you specifics, but that's the difference.
muddin38yota Well-Known Member Joined Apr 13, 2005 Location Concord Mar 13, 2008 #3 5-260x is a dana 30 axle u-joint 5-297x(old #)...changed to a 5-760x is a dana 44 axle u-joint
lomodyj Well-Known Member Joined Mar 21, 2005 Location Out in the Middle Mar 13, 2008 #4 5-297x came in TJ dana 30's
Archdukeferdinand Well-Known Member Joined Dec 27, 2006 Location Vilas, NC Mar 13, 2008 #5 lomodyj said: 5-297x came in TJ dana 30's Click to expand... And in HP non disco XJ 30s
Tetanus Member Joined Apr 22, 2005 Location Kansas Mar 14, 2008 #6 this might help Various Dana catalogs: http://www2.dana.com/expertforms/demenu.aspx If you know the vehicle the u-joint is in...this catalog will tell you all the u-joints that are for that vehicle & you can click on the u-joint part number and it will show you all the dimensions: http://www2.dana.com/expertforms/dek350.aspx
