crkid
- Jan 11, 2014
XJ HP30 that I have in my Jeep TJ; installing Eaton elocker with Revolution 4.56 gears. Few notable "issues" listed below...
-All inner pinion race shims were burred from punch - had to take all of them to a bastard file to remove sharp edges.
-Revolution did not supply pinion preload (small ID shims) or carrier preload shims down to 0.003". How is gear set up even possible without adjustment this fine?
-1310 ubolt yoke slid off existing Spicer SVL 3.73 pinion relatively easy. No play, nice tight fit, slight tug and bam removed from pinion. Same yoke would slide about 1/3 of the way on new pinion before binding. It is currently installed with my set up bearings and took an impact with non locking nut to drive yoke on to new pinion splines. Is this normal?
-How do I remove this yoke without damaging my bearings?
Thanks for your input!
