Hub getting hot?
clean and inspect/replace the wheel bearings, repack with good grease, install new seal then properly seat them and set preload. hot bearing isn't good, it's either dry or not properly loaded.
May also wanna check that your brake calipers aren't sticking, that would build up heat in the hub as well.
