RatLabGuy
- May 18, 2005
- Churchville, MD
Looking for input, and likely an HVAC fellow who's interested in a small project.
Our house is 42 y/o, originally had oil heat. At some point it had a heat pump/ac put in. Still has the oil, it's set up so that the oil is a backup unit, "secondary heat". 2 ways it will kick in to oil - it has a thermostat w/ a dial, so you can set a minimum temp, below that, it kills the heat pump and the oil runs by default. Also, if the heat pump is shut down to defrost or something, it switches to oil.
In theory, this is a good system, b/c oil is more efficient when it's really cold.
However, w/ the cost of oil what it is now, it's really not worth it 98% of the time.
I'm having an issue w/ the system. For some reason, the heat pump will run for *maybe* 10 minutes, then shut off, like it needs to defrost - although we're talking about the current 60 deg weather, and only raising the air temp like 1 deg first. Any ideas on what would cause this? After just a few minutes, it comes back on to keep going.
The real problem comes in when it shuts off - the system sees that it isn't running, and switches to oil. It then stays on oil until the t-stat is "happy" and kills everything - even if the heat pump is ready to go again. As you know, once on, heatied, and flowing, the oil furnace keeps pumping air out until it's cooled off, even if this means an overshoot of the target temp. Point being, it can end up running for several minutes and using oil when not necessary.
So i'm looking for 2 solutions.
1 - what could cause the pump to need to shut down so often?
2 - More globally, I'd rather re-wire the system so that it is only a manual switch between oil and heat. Oil costs so much that it would take a 25%+ increase in my total electric bill to make it worthwhile to ever use. Only would want it when really cold and the heat pump can't keep up (which is very rare around here).
I have no idea what would be involved in the rewiring, thinking that'll need to be left to somebody that knows what they're doing...
