I hate electrical problems
Doug
Whiteville NC
A week ago my 2002 Ford Excursion V10 started developing some weird problems. The door locks started not working right. Then the radio would not go off when you cut the truck off even when you open the door it would stay on. The auto lights started blinking on and off every now and then. Now it just quit working all together but I can disconnect the battery and it will go back to working for a little while or I can turn the ignition on and off and some times that will make it go back to working. I have been told it might be a bad ground or a gen module or an ignition switch. Has anyone had this problem. HELP!!!
my guess is something to do with ignition it controls all the radio lights and such as well as fire and fuel. i am having trouble with mine but the fire and fuel is my issue. when you turn the key and all does it feel normal?
Yes, The ignition feels just like it always has.
The locks also when working sometimes acts like they are not getting enough voltage. (they go up and down slow) :confused:
