Yep, the time is getting closer and my needs are changing....
So what do you think its worth?
Here are the specs:
93 Toyota extra cab 4x4 DLX
110k miles
22re
5spd
Cruise
AC
Full gauges like that of the sr5, tach, oil, temp, volts
side vent windows on the front doors (option)
60/40 split front seats gray cloth
gray interior
green exterior
Mods:
5.29 Precision Gears
Lock Right Front
Detroit tru-trac Rear
Bilstein Shocks
Extended Diff Breathers
TRD Heavy Duty 10 inch Clutch
TRD Heavier Flywheel
LC Engineering Header
AFM 4 Clicks Richer
2.25 Free Flow Exhuast
Rockstomper U-Bolt Flip Kit/Shock Mount
33 x 12.5 x 15 Mud Terains
15x8 Black Steel Rockcrawlers
Roger Brown 2 inch Body Lift
BudBuilt T-Case Crossmember/Skid Plate
R-n-R Custom 2 inch .120 Rear Bumber
R-n-R Custom 2 inch .120 Rock Sliders
Downey Rear Shackels
Spray-in Bed Liner
Diamond Plate Tool Box in Bed
extra parts not on truck:
Downey idler arm brace
All Pro 3inch rear springs (maybe 2inch cant remember) brand new
SDORI 1.5 inch ball joint spacers brand new
problems:
e-brake cable to handle broken
Front rotors need to be replaced (have one new in box)
Speedo off due to tire/gear set up
Couple of small dents in the bed and scratches all over from wheeling
drivers side Front seat side has a tear in it (can be fixed)
Truck is in great shape and does well off road. Pics will be up soon....
Let me know what you think, I am on the fence about selling it.. I do not need to get rid of it and really want to keep it. But if I can sell it for what "I think its worth" it will go to the for sale section soon.
Some of you have 1st hand knowledge of the truck post up your thoughts too. Good or bad.
Here are the specs:
110k miles
22re
5spd
Cruise
AC
gray interior
green exterior
Mods:
Lock Right Front
Bilstein Shocks
AFM 4 Clicks Richer
Spray-in Bed Liner
problems:
