Don Custer [@Granny], ran either the Bronco 20, or the gear set, in a D20, when he had His CJ, T-18, 258 6 cly. He built the twin stick for it! The main reason he went with it, was for the 2.72[?] low range. Never had a problem. Hope he sees this!
Swapping gears from a Jeep Spicer 18 and Bronco Dana 20 into a Jeep Dana 20 will change the low-ratio from 2.0 to 2.46 which worked out well for me. Twenty some years later, coupled with other options I would wonder if it would be worth the effort. Anyway, from the archives here is what I have. Hope it helps someone.
Lower Gears For a Jeep Dana20 Transfer Case (2.46:1)
You can change the low range ratio from 2.03:1 to 2.46:1 using
parts from an early Jeep Dana/Spicer18 and an early Bronco Dana20.
The following gears are needed.
The numbers should be stamped or cast on each gear.
#18-5-9 (18T)(39T) intermediate gear
from a 55/71 Jeep Dana/Spicer18 or 66/72 Bronco Dana20
#18-8-22 (33T) front sliding gear
#18-8-23 (29T) transmission input gear
#18-8-24 (29T) front output shaft gear
#18-8-58 (33T) rear sliding gear
from a 66/72 Bronco Dana20 (see paragraph about numbers)
The Bronco Dana20 transfer case is easy to identify. It has the shift rods located in the top-center and has a flat bottom cover plate. It's really an odd looking thing.
The Bronco rear sliding gear has at least five different numbers for the same gear. #18-8-37, #18-8-39, #18-8-58, and #18-8-65 are all common numbers, and there are a couple others. Just make sure the gear has 33 teeth and 15 splines. If it does, you should be OK.
The Jeep Dana/Spicer18s use different diameters of intermediate shafts. If you're going to use an intermediate gear from a Jeep Dana/Spicer18, make sure it has a 1 1/4" intermediate shaft diameter!
The Bronco Dana20s should all have an intermediate shaft diameter of 1 1/4". If using it, you should not encounter any problems.
You will also need an input gear to match your particular transmission. The #18-8-23 listed above is the most common one used. It has 6 splines with a 1 3/8" spline diameter. These gears are commonly found on Jeep T-90 (3-speed) transmissions used from 41/71.
If you have a T-150 transmission, the #18-8-23 (29T) gear will have to have a surface machined for the bearing retainer seal, 7\16" x 1.750".
Some cases require a little grinding for clearance of the larger gears.
A power-take-off will not work without special gears!
