ignition cylinder, switch, or actuator pin?
VortecJeep
Powered by Uranium-235
Concord, NC
2000 TJ, 4.0, 5-speed
Sometimes when I get in and crank it up, it starts and runs fine, but the radio and turn signals will not work. I first checked fuses but all were good.
Then I discovered if I wiggle the key, they will all be back to operational. Again, the jeep is running, but not the turn signals or radio.
So I thought I’d just change out the ignition switch, but then discovered it comes in 3 parts. So which one is mostly likely to be the issue? cylinder, actuator pin, or switch?
Switch.
Switch. Won't be the first one to go bad.
