I'm needing some opinions on clutch problems
jaybo86
Member
Church Hill ,TN
I recenty picked up a 97 XJ with manual transmission.
The clutch pedal is real stiff and sometimes it's hard to get in gear while at a stop like it's blocking it to go in gear,but while moving it seems to shift fine with no grinds or slips.If the jeeps not running it is very easy to shift into all gears with no problems.
Does this sound like a pressure plate/clutch problem or somethig else.
Thanks in advance for any help.
i had a similar problem in my ranger a while back. bled the hydraulic clutch (slave cylinder) and fixed it right up.
sounds like its time for a new slave cyl and a fluid replacement in the trans.
