spykosshow
- Oct 13, 2005
- Raleigh, NC
Hey y'all, got a real issue here. Just drove the 87 toyota pickup up the street and when I shifted into 2nd, the clutch gave out. The synchro's work, and you can shift the transmission when the car is off. A buddy of mine that's a mechanic suggested to bleed the the system because it's a hydraulic clutch. Tried that and it still doesn't get any fluid. The slave (??the thing on the bellhousing that moves when the clutch is depressed) moves still. We called one place and they said to replace the clutch cylinder? It feels like a hydraulic issue because you can't build up pressure with the clutch pedal, even after repeatedly pressing the pedal. Does this sound like a viable problem to y'all?
