Well, I got the bearings off of the carrier and pinion for the D44 and the D30.
A few things I've discovered.
- I figured the bearing separator tool would be the magic trick, but it proved almost worthless on the carrier.
- Two jaw puller works with a little modification. Using a big C clamp to keep it from slipping out works wonder.
- It is impossible to remove the bearings without destroying them.
- A 6" seperator would be better than the 4.5". Had to use this on the pinion.
- Impact guns are your friend.
- Are pinion locating shims and preload shims the same size? I ask because I think a few things got shuffled in the first disassembly. The pinion is marked +0 so...and I didn't find any shims I think.
- How do you get the inner race out without destroying the oil baffle?
- Does heating bearings for install work (basically do I really need to use a hydraulic press)?
- Anybody used the Alloy USA install kits? Do they come with races for the bearings and inner seals?
