Inner Knuckles
just find a junk housing and cut them off. why not just swap a whole hp44 from a ford in? you get the hubs you want, a high pinion, and eliminate the CAD also. just cut off your brackets and weld them on the ford axle.
well i have a jig setup for the C's, from doin it on a Scout d44. i just figured that swappin in a whole axle and transferin the perches would be a whole lotta work? having to line it all up and all? and couldnt you get rid of the CAD by getting a new long-side shaft?
another option although expensive
http://p.hostingprod.com/@highclearance.com/index.html
here is some good info
http://pavementsucks.com/forums/viewtopic.php?topic=33915&highlight=crane+
http://pavementsucks.com/forums/viewtopic.php?topic=72549
the best idea http://pavementsucks.com/tech/dana60swap.php
search around on that site, tons of info
if ya want a D44 or D60, they are cheap new from Dana but are ball joint, or if you want the Kingpin D60 unit, you have to go aftermarket, which means $$$$$$$$$
So what is cheep for a Dana 60 from dana direct and how you get one.
J
Usually you can get them from most axle builder shops. They are fairly reasonable, about $190/pair for the D60. But, they are ball joint style, not kingpin.
Rob
