sharksanddanger
- Apr 18, 2005
- Reidsville
I have a doubler that NWF made to go on my nissan and it comes with a new shaft for the nissan case with a 23 spline output to enable you to put a d300, atlas or stak behind it. Well I got an Atlas and the splines are an extremely tight fit, actually for the shaft to go in there I'd have to beat it with a mallet probably 10 times for it to seat all the way and I'm kind of afraid to do that. Picture of how far it will go in(about 1/8" or so) before I'd have to force it in there.
It should be a tight fit but not that tight. It would also make for a huge PITA to beat one case onto another and then still have to separate it if something was wrong or broken.
I'm going to call NWF and tell them about it but I know of others running this adapter and shaft without any issues. I guess my question would be could I take a tiny file to each of the splines to make the shaft slide in there a little easier?
Ideas, opinions, comments, sexual jokes on shaft insertion?
for actually test fitting it before hand stuff like this is very common when mix/matching custom parts...
