4x4fever
- Jul 5, 2005
- abingdon,va
went DIY on my hydro assist. have a j-20 box tapped runnin 8x2 ram with a tranny cooler on the return side of the line and stock pump.
number one. do i need to put an extension on the pump to hold more fluid?
and my concern is if the jeep is on jackstands with the draglink disconnected via the pitman arm when i turn the wheel the hydraulic ram doesnt move left or right till full lock then it goes on about its merry way. is that correct? it only assists at full lock or when the draglink is hooked up and im trying to turn its pushing enough pressure for the ram to work with it instead of at full lock?
